If you serious about this you will need to get All these parts of the donor car . Fly wheel ,Chutch pedal assembly ,slave cylinder,All clutch lines and brackets ,Shifter assembly ,brake pedal assembly ,brake master cylinder ( clutch uses brake resevoir for fluid) Clutch assembly of your choice ,You may need wiring harness as well .
As was said before ,this would be alot of work and cost , but if this is what you want to do go for it .
