Need help.. I own 2009 Mazda 5 touring. Problem occur when I change my stock wheels to 205-60-r16. the rims are from mazda6 with 16x7. but now I return the stock rims, Im now having a heavy feeling on the steering & shudder over bump. dealer replace driveshaft & hub bearing on the front passenger side and they align all wheels. I'm still having problem, their is also a loud tire noise on the front passenger side. First I'm suspecting the bearing but dealer already replace it. but noise still their.
Any advice what cause this problem? I only hear this on the front right side. notice that noise is not changing even the road change in condition (smooth to rough).
I also notice dent on the middle part of both front strut. I this normal? Just thinking if this from the mazda 6 wheel I put because it is a 7" wide with 55 offset.
Thinking other parts that may cause this like: power steering, bent steering component, tie rod, or hub assembly.
would their be an effect if I have a bent strut? I will post the picture later. I already try many dealer but they said their is no problem. I will try to record the noise & post link here.
Thanks in advance Guys. I live in Virginia.
