SSAFC maps or etune
570msp
2003.5 msp laser blue #2500
I finally put my SSAFC in and was wondering if anyone has a map for 10 psi with a front mount setup. Or if anybody can do an E-tune. Any help would be greatly appreciated.
if you have a wideband, your best bet would be to hook up one of the orange aux wires to your wideband for datalogging. Start off with the stock supermap, datalog a few runs and tweak that map until your AFRs are perfect for your mods. If you don't feel like doing that, you can go to the split second thread and try one of the maps on there.
edit: figured I could be a little generous, here is the thread: http://www.mazdas247.com/forum/showthread.php?123620555-AFC-SplitSecond-PSC1-Map-Library
I don't have a wideband setup. I was mainly looking for someone to do an e-tune if possible without the wideband. I'm running the stock map now and it absolutely fixed my hesitation. I'm just looking for a little bit more power out of it or maybe even a gas,saver map.
I would stick to that map for now until you get a wideband. All of these maps won't have the same end result on every car since everyone's car will react differently to a map due to different setups/mods. Knowing your AFRs is essential when it comes to loading different maps and/or tuning. You are pretty much taking a shot in the dark loading a map without a wideband which can be good or bad....hopefully good. Either way, you will probably end up needing to tweak the map anyway for your setup. But to be safe, just stick with the stock map for now.
Would uploading the supermap be safe? Because I'd like to try and get the full potential out of my 10psi
the supermap is the stock map on the SSAFC. It's the map that comes preloaded brand new and what most people including me, start out with. Hell, Im still running the stock supermap. Did you buy the afc new or used? If new, it's the supermap already. If used, you can reload the supermap just to be sure you aren't running a map setup for someone else's mods.
no, the ssafc can only have one map loaded on it. The ssftc loads two maps, map a and map b or fuel and timing. The afc uses map a for fuel and map b is not used for anything.
Ok I appreciate the help. All if thus is new to me but in trying to learn as much as I can through the forums
You really shouldn't be running 10psi without a wideband 02 sensor. I run the FMIC map on my car at about 9psi and it runs great. When you select a map make sure you don't choose one for 440cc injectors unless you have upgraded your injectors.
