Continental VikingContact 7 winter tires, highly rated by TireRack and Consumer Reports and featuring a really attractive snowflake sidewall design pattern https://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=304 225 65 17 extra load about 10/32" remaining tread depth (these tires new are 11/32"), see pics, no prior damage or issues. mounted on Mazda factory CX-7 wheels, obviously these are older but wheels don't expire. These wheels are cosmetically imperfect and have some inner lip corrosion and poor condition center caps--pre-approved for winter salt and seasonal abuse. Being true Mazda factory wheels, no worries about cheap, poor quality imported junk bending or failing from pothole impacts. They're true, and they balance out perfectly.
Fits 2017-2025 CX-5 all trims, whether your car currently wears 19" or 17", is turbo or NA.
$765 for the set-- nearly new and already mounted/balanced to compatible factory rims. No TPMS programming required, simply bolt on and go (at least from my '18 and '20 CX-5 experiences).
See photos. Won't be cheap to ship, but willing to facilitate via UPS or FedEx if shipping is at buyer's full expense. Located in suburban Detroit. This CX-5 and its driver relocated to the US South after barely using these tires. This is the second set of winter tires that I mounted on these rims since 2018. I use/d these same VikingContact 7 tires on two other cars, and they're very good.
Unfortunately, not a match for CX-50, but fitment decisions are 100% buyer's responsibility.
