Scangauge installed!
toucci
'03.5 Proteg 5
I recently ordered and put in my scangauge OBD-II tool. It displays the OBD-II details the computer keeps secret from you. Stuff like water temp, intake temp, mph and tach in RPMs, battery voltage, closed/open loop status, current gas mileage, and gallons per hour. It mounted quite nicely in my dash too:
Installation involved hooking it up to the OBD connector.. and thats it. Way cool. I got it mainly to track mileage (it does trip, tank, and daily recordings) but all the extra gauges are awesome. I wish I had my injen still to compare temps. Only downside is the cost ($170) but that's cheaper than the time and effort required to install inexpensive seperate voltage, water temp, and RPM gauges.
http://www.scangauge.com/ :)
very interesting, too bad its not more appealing to the eye....kinda blah but kick ass none the less!
would it be possible for you to snap a few pics of the gauge settings(color options and screen displays, maybe at night?) im really thinking about buying one of these enstead of 8 gauges.
Sure, I'll go take some pics after dark. What colors do you want to see?
Here ya go.. sorry if they're not sharp; I was shooting by hand
Wow, as mentioned the first color matches pretty damn close! This is a mod that i will purchase when i move onto my interior. Thanks bro
Toucci, does it measure the vacuum? I saw on the site it says it measure the manifold pressure, but not on all cars. Have you tried it yet? I'm wondering how it'll work w/ the turbo...
which odb port did you use? iirc, the MSP's obd port under the dash is filled with goop and doesn't work. i think.
It uses the MAP sensor which I don't believe our cars have, do they? Either way it's not giving me any info there.
