Samco hose install
L8R said:
yes, it should...?
i think
put em on.. but the short small hose that goes under the EGR is like.. way shorter than the old hose.. the clamps just barely clamp on .. right on the edge of the hose.. which is barely on the nipple.
u had the same situation, not really a problem. just make sure it is over the nipple part
peace
Pictures!!
Here you go.
Nutari, what do you have your header wrapped in? does it actually do/help anything?
stretched yak scrotum blessed by an ecuadorian shaman. it gives the exiting gasses spiritual powers. right nutari? (thumb)
DEI Header/exhaust wrap. Lowers underhood temperatures.. and according to DEI.. insulates the header.. which makes the exhaust gas travel faster... (first)
.....yeah... (boom07) thats it capn... (boom07) (boom06)
do you notice a big difference when you open up the hood after it's been on for a while? (w/ the headerwrap)
looking good. quick question for L8r, when you installed your hose sleaving kit on your hoses did you flush your radiator or just slide the wrap on and that was it?
-not meaning to thread jack, just curious.
I think you would have to flush it.. all the fluid would drain out.. well.. if he sleeved the bottom one too.. if just the top, then like.. some would spill out... (braindead
