Pilot bearing install Fidanza flywheel
br289165
'02 P5/2 Audi A4s
Anybody have good advice on how to press in a new pilot bearing to a Fidanza flywheel without a press and not damaging the bearing?
It should not need to be pressed in.. It should simply need to be pushed in..
If you need to "Help it" in, you could get a socket that is the same size as the bearing and hit the socket with a hammer (Lightly) to get the bearing seated.
Do not let it go in crooked, it will bind and brake.
