Hi,
I have an oil leak coming from the passenger's side of the engine near the timing cover. I had originally thought the leak was from the crank shaft seal (which was replaced with the timing belt), but upon further inspection while doing an oil change, it appears to be coming from higher up. It is mostly on the back side of the block along the timing cover. It's difficult to tell how high up it starts.
Is there a common leak something in this area that is common to leak?
Thanks for any help.
