OBD2 Scanner/App: what sensors/values to monitor?
Today the temp peaked at 226 on my way back. Yesterday it went up to 222 on the way over. Same route, similar traffic condition. MPG is down to below 35 which is the normal average.
What’s the coolant temp in relation to the engine oil temps ?
It goes up when in traffic but otherwise stays below 200 when the oil temp hikes.
The first chart is from yesterday afternoon, one hour trip back from one job. The flat line is because I forgot to disconnect and it kept logging.
The second one is this morning, half hour trip to another.
Have you ever cut open your SuperTech filters? I saw a video and it looks like it has a center tube with the largest openings for filtered oil to come through. Most filters designed for longer OCI have center tubes with small cuts/holes.
Something to keep in mind on engine oil temps. The 2.5 turbos have an actual oil temperature sensor, most of the NA models do not and it is a calculated temperature based on engine coolant and vehicle load.
Thank you! I didn't know that. Was surprised that I could even get the ATF temp on a CX-3 mid trim. Even if it is a calculated number, it is the only number I can go by.
I will make a chart later for engine load, coolant temp, and oil temp from the log.
ATF temp is real in any Skyactiv and measured in the pan.
I tried two phones (different Android versions). While the calculated engine load is monitored, it is not always an option to choose from the log. The drive this morning didn't include the engine load as an option so I used vehicle speed. 🤦
An earlier log did include the option but the info doesn't seem to be right.
Either way, the dip in the record is concerning. Not sure if the BT lost connection temporarily or the sensor lost power.
For reference the coolant is the fluid that regulates the excess heat of the engine which would in most cases average around180F.
Check what’s the condition of the cooling system of your car bc oil is meant to lubricate and handle the temperate range where as coolant is to regulate the excess heat (above 180F).
The coolant temp has been around 194 for as long as I can remember. Coming from a MINI that suffered an overheating episode, this is the only temp that I was watching on the CX. It stays constant after 8 years and 150K+ miles. There was no leak and I still have more than 3/4 of the OEM jug from 2017 after occasional top-off. I thought maybe this is the one thing that was indeed life-time quality. 😂
The first coolant drain/fill was this July after the second drain/fill of the ATF. The old fluid was clear though the color has faded. Let me think what else it could be...
Found a pic from 2019 when it was 2.5 years in. That is the running temp that I remember.
You’ve never changed the thermostat or the water pump ?
Hello are you still monitoring the stats while you drive? If so, can you check if you have two sensors/values for the engine coolant temp, A and B? 🙏
Yes there are, delta is around 15-20F.
I’ve noticed the oil temp for engine and transmission is now part of paid version.
You held off long enough! I paid just to get rid of the banner that took up screen space. 😅
Appreciate your reply. What does Temp B mean to you in terms of how the cooling system functions?
What banner 😅
Yeah. That’s the ball park of 2 temp values in a closed system, in my case A was lower and B was higher.
I used that app to test it and see what option and ui it has which isn’t the best but curbing options to push for paid sub without improvements isn’t smart on their part.
I’m looking for an app that’ll have better ui and more reliable app, I’ve cases with this app that it would run in background without a way to terminate it. Something small but annoying.
What banner 😅
Is it still $5 for life? But I get it. I still haven't paid for Pandora yet. Wish they would do $5 for life.
So your A and B temps show a cooling system controlled by one mechanical thermostat and no further intervention?
Edit: Found Jango!!
During my long drive yesterday I monitored the oil temp in relation to rpm. If I keep the rpm below 2500, the oil temp stays below 212. On steep inclines over 152E, I bit my lips and stayed in the slow lane in 6th gear. 😭 When I couldn't hold back on I-5S, the temp climbed to 220+.
When the traffic slows and rpm decreases, the oil temp doesn't drop right away. It comes down gradually over a bit of distance. There are obviously other factors in the calculation. I monitored the temp in relation to engine load before, both calculated and absolute, but they are all over the place.
