Yes, if you are rebuilding the EGR, then the screws that hold the little motor are made of nothing sturdier than swiss cheese.This guide and the whole thread are awesome but doing this recently, I cannot stress enough how bad the screws are. The bolts are taken out easily enough with a tiny ratchet and shallow socket but the screws... They wanted to strip without any pressure at all. We had to take a torch to them and pull them out with pliers.
However, you shouldn't need to rebuild the egr as lubricating the spring doesn't solve the issue. The problem is internal rusting of the motor which you cannot replace. Rather you replace the egr as a whole as its a common maintenance item anyway.
