mazda splash guards
I beleive there are no splashguards from MAZDA for the 5 doors. :confused:
But, to protect my body sides, I bought splash guards from Canadian Tire, at something like $10can a pair.
Does the job well, no complaints. And look isn't too bad either.
Have a look.
I checked with Mazda no splash guards for '04-05 models...they said check with Crappy Tire haha
Canadian Tire:
http://www.canadiantire.ca
And I actually have not found my splash guards on their web site. So, you will need to get there to find some.
But, on the web site, you would be able to locate a store near your place.
marineaulu said:
Canadian Tire:
Oh i went to CR before and saw those guards, but by what means do u put them on? I mean there isnt any hook ups on the car..
Just used two srews per mud flaps, which are provided with the mud flap kit.
I fixed them through the plastic body side extensions. I aligned the screws so that they did not came in contact with sheet metal.
Yes, you this will make holes in your plastic body sides.
Yes, it is a solid installation. I went through a whole winter with this setup, and no problems at all.
Little advice, make sure the car is on a levelled surface when installing the flaps.
I used a measuring tape and a level to ensure a symetric installation, and to ensure the flaps are parallel to the pavement.
