manifold coating
just want to get some input on this downpipe i found jonboy...what do you think about clearance issues?
That looks like another Silvia down-pipe. It's probably not much different than the other one, except the other one had a separate wastegate runner.
the flange on the botom is what hits. it needs to be cut towards the top and make it go under the turbo insted of towards the passenger side. my welder said it can be done easily with stainless steel, he said it is really easy to weld. i will have maybe a $100 in it with buying it and paying to get it basecially reclocked. in other words it needs to be angled differently.
can you tell me exactly what it is hitting? is it the A/C compressor or A/C compressor bracket? thanks...
I'm guessing the hook mount that is just a tab coming off the housing with a hole in it. I could be wrong, though.
i believe its the bracket as well. the hook mount loks like it be in the way if the dp comes out at a diff angle. such as that one.
