has anybody done anything to their valve cover?
VFR pilot
'03 P5, '94 Miata, '00 VFR, '01 SV
so i open the hood up on the P5, and there lookin at me is some off-color lookin valve cover........(boom03)
i have my miata one powdercoated black....
anyone done anything to their's....
Not powder coated..but high temp paint!
Ch(wink) as
did you just take it off and paint it and bolt it back on?
how did you clean all the oil off of it?
Yeah..first unbolted it..than got some soap & water..and cleaned it..then power washed it..than lastly sanded it down a little..than let dry...and paint 2 coats..and bolt right back in!
Chas
Protege5Gurly said:
Mine is chromed ... click the sig for pics.
Pe@ce
I really like the chrome.....is that paint or did you buy something else. Same question with the Exhaust manifold shield.
I painted mine with High temp paint. There's a how-to on painting valve cover and heat shield in the how-to section if you are looking to paint it.
I've seen the how-to sections and I think it would be pretty easy. Can you paint it chrome? It sure doesn't look painted it looks like something out an order magazine.
I don't think chroming is something you do on your own, you'd have to take it off and give it to a shop that does that kind of stuff. I guess you could try to find the shiniest silver paint out there and try that.
Hmmmm.....i don't think its worth it to me. I'd just a soon paint it than send it to a shop and wait.
rubbing compound, a dremel, and a whole lot of time can get you chromed.
i did the letters and it took half an hour.
if your car is older, than yes I hear you should replace the gasket. On our 3.5 cars, I don't think it's a problem to re-use the orig.
Jspec said:
did u guys have to replace the gasket when u guys painted the valve cover?
I did it..they don't cost much at mazda!
I am not sure about the tq specs or the order..but i did criss cross..(uhm)
chas(coffee)
Pe@ce
Wow! That's the nicest valve cover I've seen on a P5 yet! (shocked) That must have cost a fortune.
I think I'll just paint mine with high temp yellow to match my car.
