Hardpipes
BOOSTR
1 OWNR MSP
Anybody using the kit form turbohoses? If so, are you satisfied with them and can you post a picture of them installed.
^ i just got this kit! it is a very good quality kit!
one thing i liked the most was the fact that they use hump couplers & 90 degree
elbow for the t/b pipe. ill post up pics later this week!
Im a bit confused by the picture in your sig. Do you have a DG front lip that is 100% carbon fiber? I thought only the lower part of the grill was carbon fiber? How did you get the entire piece in CF?
Thanks 1FASTMP5. $395 is not a bad price for them, the picture on the website looks good. I'll wait for your pics.
yep.....it's full c/f. it's custom made by dg..... they have only made two of these lip's ever. one was on the protosport p5 and mine.
Bhamsan said:
Yes, I'd also like to see these pics. They've been talked about a lot recently.
no problem, i should have them by this weekend then ill snap some photo's for ya. peace
I will also let you know about the quality of this when my set get's here on friday!
Judging from the picture on www.turbohoses.com, the nipple diameter appears to be the right size.
I also contacted essential speed, but they said that there hardpipes were not compatible with an INJEN. The INJEN diameter is 3/8", for the stock bpv tube.
I for one hope that they work with the INJEN.
Hard Pipes
Are These Spool Pipes Or The Ones You Guys Are Talking About???
They do not have the hump hoses, so they are not turbohoses.com. Appear to be a different type of metal.
I have the turbo hoses hardpipes and I really like them. I have pics on my phone but I am having trouble e-mailing them. I will try to scan my other pics of them on my computer this week.
Those look like Spool, but they are definintely not turbohoses. I'm not sure if they make them in polished silver, but on the website, it says you can only get them in black, blue, or red. I want some polished silver ones to match my Injen, but I'll have to call them to see if they can make it. The turbohoses runs with the stock BPV, am I correct? So, if you wanted to run the dual BPV/BOV setup, you'd have to go and get a BOV and flange and have it welded on the IC to TB pipe?
Actually, they just updated the pics of the pipes on their website, which I haven't seen until now. They look pretty sweet, but it still doesn't say anything about getting polished pipes.
The blue, black or red choices are the color of the silicone. The pipes come polished. Yes it uses the stock BPV, yes you would have to get the flange welded on.
