Fog Light replacements?
PapaJohn
Protege5
I’ve just recently bought my first car, a protege 5, and both of the fog lights have been destroyed by rocks getting kicked up from the road. They are in no shape to be fixed so I’ve been looking at replacements, and have come to find, there are none. Does anyone have any aftermarket options available as both marketplace and picknpull lots don’t have oem lights. Thanks in advance
Check with eBay for a set of used in good condition fog lights.
It'll help if you have the part number for the search.
My 2002 Protege doesn't have fog lights but I did find some on eBay in great condition, got the wiring harness on eBay, and necessary relay too.
Hope this helps.
Check out JP Parts Intl
Jp is a good guy with tons of Protege parts. He usually has a set of fogs for sale.
A while back I found something that worked as a replacement, think I snagged them from Walmart at the time. Just needed a little finessing to get them to fit.
I used the wire harness connectors from my broken fog lights and spliced them into the replacement wire harness in each new light.
I recently removed them as I’ve since acquired some used originals.
I’ll check him out, but I also saw some people slap some hella 500 amber fog lights on and might go that route. I’ll send a photo when I figure it out
Little update on the fog lights. Bought some Hella 500ff because I thought it would be a breeze to install. After a little drilling and some finishing touches I thought they came out quite well and I wired them up off the original fog lights wiring. In the second photo the dot is where I drilled to put the bolt through on the 500s.
