Feeler.. BBS wheels for Protege & P5
This isn't an official sale post just wanting to see if there would be any sort of interested in these wheels as they are just currently taking up space in my garage. P5's are pretty limited on wheel selection especially on lowered cars unless you want to start cutting/adding flares and doing crazy stuff so i though they might appeal more to the people on here more than those on craigslist..
I had the centerbore bored out in order to clear the P5's hub. The wheels are 5x114.3 BBS RG023, 16x7 +45 all the way around and are a set of 5. The set of four that would be on the car are in great shape and the 5th wheel has some cosmetic blemishes (careless with a tire iron maybe?) that were there from the previous owner. Regardless all wheels are perfectly strait and balance like they should. All 5 wheels have 205/55/16 tires, the four are matching goodyears and the 5th wheel has a yokohama, all 5 above 90% tread wear. All 4 caps are present and are in perfect working order, the original BBS cap tool is included as well. The only thing i wanted to note is that a small 3mm spacer was used in the rear to clear the brake calipers and with the drop my p5 had (stagg struts and tein s-techs) the fenders did require a roll.
If there is interest i will add the proper signage as well as better pictures. Wheels are located in central TX and I would be able to meet anywhere in San Antonio or surrounding areas as well as Austin and anything in between really. Would be looking for a local sale and not really interested in shipping for the time being.
