I have been searching, and have seen many people recommend coil packs for the MSP. But i cant seem to find people that replace the coil packs and then problem solved.
When the car is at operating temp, I have been having some problems while boosting, the car seems to fall on its face. ~7-8psi
It makes it miserable to merge onto the freeway sometimes, It feels like the car is pulling so much timing that I cannot gain speed, im pretty sure my old celica was easier to get onto the freeway.
EDIT: I'll put it this way: can msp's burn rubber in 1st gear? cuz mine won't and I would assume it should be able to.
I know some people will say its heat soak, but in WI it is not hot. With a customMSP SMIC, the temps stay pretty low(i even probed the intercooler last summer).
I believe that the stock coil packs are on the car. I do not have a CEL so i was under the assumption that I would not need to change the coil packs until i get a CEL for them? I checked the coils vs the shop manual, and they seemed fine (resistance wise)....
I have replaced the plugs and made sure they were gapped correctly (.028 -.032) [I have tried this with 1 cooler plugs and the ones that came with the car... no change for either]
Anyone had great success with the new coilpacks?
