Cobb RSB
SingleFin1969
MS3
My Cobb RSB just arrived!!! Now I need the Eibachs to show up, so I can do everything at once.
You'll love the RSB. Makes a world of difference. I suggest you set it to the stiffest setting because I have mine at the softer setting and the car still pushes too much for my tastes but YMMV.
forget the springs. that rsb will take you 30 minutes. put that s*** in there!
also, to install it, it's not like you have to mess with the springs or any other pieces of the suspension (yeah yeah...endlinks...obv)
I just installed my RSB the other day, its really easy like mentioned maybe 30min install time. Make sure you tighten the endlink nuts before the swaybar nuts, gave myself a headache doing that. In combination with the eibach springs its really sweet, you'll like it.
+1
If you believe COBB and Hotchkis, then the COBB RSB at the stiffest setting is the same as the Hotchkis at "less stiff", which is what I'm running now and love.
