after having my clutch replaced due to the fix for clutch chatter I have had some problems, extremely hard to shift into 2nd when cold and also grinding....
now I've noticed that if the car is stopped and I press the clutch down it makes a clicking sound coming from the engine area... you can hear this when you park your car in a parking lot... it happens if it is in gear or not in gear..... i know its normal to hear sounds when you make shifts into gears when the car is stopped but is this normal??
also for anyone who is considering getting the clutch replaced by factory I would advise you not to because my transmission was a lot smoother before I did the fix.... the bunny hop wasn't that much of an issue really....
