I was thinking about how 2 different MSP's, that are identical and totaly stock, could have different levels of hesitation or one have it and the other not have any at all.
I have a hypothesis. Its the ECU learning system and I think a built in safety. If you take 2 owners I have a feeling the one that drove harder or tends to shift higher and try to accelerate faster will have a higher degree of hesitation then the other that goes easy on the car day to day. Perhaps the computer is trying to either get a proper break in period and it will go away in time or it is intended to ensure the longevity of the car as mazda was not a 100% secure with a turbo on a car never designed for it.
Either way I think the car has a few "safety" fuel maps it implements when the car is driven to hard in mazda's opinion.
This would also explain why mazda has no problem brushing people off on this. Either becuase the car will come out of it or they feel you are driving the car to hard and they could care less about complaints.
This also explains why resetting the ECU cures the problem for only a short time. Then it comes back becuase the drivers habitts have not changed.
This is all just off the hip thinking and I have no proof but it explains some questions still out there.
THE TEST
To test this there needs to be 2 MSP owners that one claims to have the hesitation (dirty) and the other does not (clean).
Each should reset the ECU and begin to drive the car as they normaly do. Then after one has the hesitation kick back in and each has similair milage on the reset ECu, they swap ECUs. Then start to drive as they do day to day again and see if the former "clean" car gets the hesitation or if the "dirty" car redevelopes it.
THE TEST
