Nero isn't the most user friendly program at first- but it is certainly the best. The first thing that you want to do, is organize everything into one directory. I'll use my setup as an example- I have a folder on my desktop that says "My Music", inside of this I have created several more folders named Easylis, Altroc, Claroc, Techno, Rap, etc, etc. This will simplify the process immensely because you will not have to search through a bunch of directories to piece together a CD. A simple point and click and you will have everything that you need. I use 80 min cds and you can fit a ton of music on them. Nero is nice because it actually tells you if and how much you are exceding the data capabilities of the cd. If you are transferring albums, and have a large directory, just keep them seperated by folder and drag and drop them into a generic "burn" folder on your desktop.
Once you have everything organized you start Nero, and select a data format when you are cycling through your options at cd creation. Make sure all of your songs are saved in mp3 format! WAV files are what a normal cd player plays, and they are huge! If everything is not saved in the right format, you are defeating the purpose... At this point you go to your directory and either double click or "maybe" drag and drop the files that you want to burn (can't remember, at work). There is something that shows the mb limit on the cd- so make sure you do not excede this. It is important that you selected "data" earlier, because I am pretty sure that Nero will convert mp3s to WAV if you select the music cd option. After this- click burn and you are ready to go. This is long winded and full of too many "I think"s. Hopefully it helps though, but w/out the program in front of me I'm just not quite sure about all of the specifics. Nero is a rockin' program though, once you play with it more- you will see what I mean. It is really good for software with burn protection, because you can save the cd image to your hard drive, then burn it to cd. GREAT for OSs, games, etc- as long as you have a product key... err, I mean- well, backing up your software for personal use.
Good luck, I'll check back later.
[ 02-20-2002: Message edited by: hixtrix ]
