the mounts are in relation to the chassis, not the motor...since the BH chassis was available with the BP engine then motor mounts for a 95 BP powered protege will bolt up to your car
that does not mean that the z5 mounts will bolt up to the BP...and that's actually doubtful considering the block is different (as opposed to the same block but a different displacement), but I wouldn't be able to tell you for sure
check www.onlinemazdaparts.com and see if the part numbers are the same between the two's motor mounts...if they are then yea they use the same mounts, if they are different then no
