Could be. Aussie CX9s are rated at 4400lbs, or 2 Metric tons. Weird. .
I'm guessing that even the Aussie limit of 4400lbs is based on the hitch capacity not the true towing capacity of the car. If there is an additional transmission cooler that is cheap and easy to install. I just don't see what is really different between the CX9 and the ML350 or MDX both of which are rated at least at 5000lbs. Not sure whether Mercedes does anything different with the diesel ML350 as that is rated to 7000lbs. I think that simply requires a weight distributing class 3 set up.
From a trailer hitch website:
CLASS II TRAILER HITCHES
Class II hitches are weight carrying (WC) hitches rated up to 3500 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 300 lbs.
A Class II tow hitch usually has a 1-1/4" square receiver opening.
A higher class drawbar does not increase the towing capacity of the hitch.
Class II hitches usually attach to the bumper or vehicle frame.
CLASS III TRAILER HITCHES
Class III hitches are weight carrying (WC) and also are weight distributing (WD) depending on the vehicle and hitch specifications.
Not all Class III hitches are rated to be both. See the specific hitch for that information.
Class III hitches used as weight carrying are rated up to 6000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 600 lbs.
Class III hitches used for weight distributing are rated up to 10,000 lbs. gross trailer weight (GTW) with a maximum trailer tongue weight (TW) of 1000 lbs.
A Class III hitch usually has a 2" square receiver opening.
A higher class drawbar does not increase the towing capacity of the hitch. To use this class of hitch for weight distribution requires a weight distribution system.
Class III hitches attach to the vehicle frame only.
