And just to keep everyone guessing at what the hell I'm thinking...my wheel setup will probably be 15X10 on the front and 13X8.5 on the back. The reason is a secret for right now.
Wouldn't a lower rear end put more weight on the rear wheels? Seems like simple physics to me, but idk why you would do it except to balance the car out.Let's see....having the back lower will put more weight over the front wheels and give you a little more front weight bias than if you had the same ride height front to rear.
Obviously more rotation.....
You want the car to look goofy.
I like that you are thinking outside the box and trying something different instead of being a lemming. I guess that is the beauty of FSP, there are alot of cars that have potential, it just takes someone willing to try.
Kudos.
Hmm, you might be right. I was thinking when you do cross weights that raising a cross ride height will increase the weight to that cross.
Hey you going to use 225/45 or 225/50? The 45's are pretty darn light.
Van
Neither...I'll wait for the official memo from Hoosier before I spill the beans.
What did you have to do to mod your coil overs?
It hasn't been done yet, but the only mod needed should be to the rears. The bottom bracket needs to be changed by increasing the distance between the two holes a little. I'll just have new brackets made and welded on while the inserts are out at Koni being checked.
Ahhhhh....the 2xx......That would be cool if they come through.
We have just received word that Hoosier will begin production in late March/early April of this new Miata friendly size in the A6 compound. 255/40r13.
Actual specs will be posted on our website as soon as they are available.
Chris Harvey
aka
Trent@TireRack.com
Yep, thats it. That ought to save a few rotating pounds on the rear of the car.
