I might seem ballin, always buying new parts and all, but I'm literally broke as **** in real life because of it. lol.
By far, the most complicated, longest, hardest, most exhausting, and most worth it mod I've ever done. (breakn)
You will say the same thing when you boost. lol. Congrats on the swap man! I just caught myself up and read the last five pages lol...woah!
I was the same way with buying parts left and right. Seems like once you have a majority of the stuff you just want to spend everything you have so that you can have everything together and finalized! lol. That's why now i'm trying to decide if I want Neox's forged items and go big at some point, or work my way up and get other things. Depends on once I speak with neox. We will see. lol..If I get his stuff I won't even install until next summer, unless something happens before then. lol
Man that looks like a good swap. 2-3 days is not bad for a swap. Usually takes some people(me) a week ot more. Yea Petz can pretty much fix anything. Give that dude a 17mm wrench and he'll take a engine out with it. lol. hope u can fix the small little kinks. Now its time for BOOST!!
pm ghettobubba2001...I think he has a rear seat. He had a FS up but it was closed b/c of proper pics. but you should pm and see if he has rear still. they look like mine, which i think is what you were wanting.
you can wire up the speedometer directly from the tranny to the gauge cluster. i just have to check the wiring diagram to see which wires they are and it will work again :D
watch out with him though, thats the guy i bought my hiboost stuff and my turbo from
he's a cool dude, and i went down to florida to get the stuff so it wasnt a big deal but he can take a while to ship stuff, like 3 months lol i bought a exhaust from him and he never sent it so like after 3-4 months he sent me my money back...might have been longer actually
oh yeah, i met up with em to get teh RH's
it does take a while to get hold of em though whether it be email or text or PM
not 100% sure. but i think the p5 had abs. therefore the speedo was reading from the axles. for your car, you have a sensor in the trans to read speed.
the only part of this I have a problem with, is that the P5 axels, hubs and trans are all in his car... so #1, he'd know if he swapped over ABS parts... #2, he'd have to use the same speedo setup the P5 used, as the car likely isn't equipped with a sensor both in the trans AND at the wheels... likely one or the other.
P5 rear seats wont fit, or else I would of just used mine.
Bah, I guess I'm leaking a lot of something. Gotta go look n see.
It's not a lot, just more than I'm comfertable with. Maybe its run off? I'm gonna tighten the drain on the trans, we might not of tighten it when we drained it on the p5.
you can get them to fit. i used nut inserts and drilled holes where the P5 attached through that little bracket, droped the nut insert's in and used regular hardware to attach them
also, you should cancel that FMIC core order and hop on this
http://www.mazdas247.com/forum/showthread.php?t=123753126
I know thats the best fmic you can get, but I really don't like the part of my crash bar disappearing. Safty>Performance
I was right, the leak was from the drain not being tight, at all. lol.
