WW Upper window spoiler
steve_protege
Contributor
2000 DX
Anyone know where I can find one? Its part #867903 (I think?) in the WW catalog. Im including a picture of it. Can someone locate one for me? Thanks.
But I heard if its not installed right and air gets under it, then it will just get ripped off. Isn't there another way to do it?
i think the guy who runs the site is on here as JDMSam and it is legit. But i know what you're saying about the aol, he must lose alot of business because of it.
You can get to his site by typing in www.*************.com so he gets some brownie points for that. It looks like if you enter from that URL you would never know it was an AOL account.
JCell said:
it'll probably just fly off after a while....
It is true. Happened to me 3 times! originally, i used the supplied double sides tape and that didn't work. Second time, i went with urethane glue that works with side skirts, and that didn't work. 3rd time, sanded down the glass to make better contact and again, it didn't work. Lucky for me, everytime i flew off, there was no car behind me.
I've had enough with it. As good as it looks, you just keep having the thought of it coming off.
Btw, the 3rd time i flew off, it got damaged in one of the corners when it landed. I just wish there was a better way for it to hold securely.
However, there is a member here or two that has had no problems with it at all.
Good luck
Good luck
So does that mean you have one for sale too??
are you guys using 5lb scotch exterior tape? if not, it will work. i had it holding my CF sideskirts on and most of my CF pieces. that stuff is like a rock.
it can be found at walmart. its redbacking , and the tape itself is gray.
whats happin is they prolly not gettin a good seal and air is gettin under it and poping it off,
