I have a counter on my site that points to where people come from. I like to visit and see what they have to say. Most are nice and have educated people giving arguments on one side or the other about whether the ESC can work or not.
However on some, there are those who choose to bring up tired and already proven to be false stories about my products from other boards. I must have pissed several people off--especially the Probetalk guys, cause they are the ONLY people in this world who seem to hold on to something that has been proven I never actually built--about ten years ago.
OK--The average alternator is 85 amps. Factory AC cars are usually fitted with at least an 85 amp unit, and the newer the car the higher amp they usually have. An old Toyota Corolla from 1982 would only have a 40amp unit. So you are correct--factories design the alternator to support the total amperage used by the AC, fans, lights, wipers, stereo, etc if all are working at the same time. With mechanical radiator fans long gone, and the resulting dual electric fans on all FWD cars, and electric windows and locks standard on most cars the amps are reaching 100amps--even on the basic car. So if you have the AC on, a custom high amp stereo, the lights, wipers, and every conceivable accessory going you may only have a 20 amp reserve. That would take a longer time to recharge the batteries.
Modern alternator design allows them to recharge faster that older styles, and the fact is that factories have had to make more efficient alternators to keep up with the short runs we now all take to the corner store. They also run cooler and are rated lower that what they are actually capable of doing. If the diode pack and rectifier were changed on a modern unit the amp rating would likjely go up 20-30 amps.
This would be beneficial to the ESC batteries in that they will take a faster charge than a standard battery. If the alternator is rated at 100 amps, it can run 100 amps for 10-15 minutes and will finally start to heat up. With the smaller lightweight batteries that charge in a few minutes there is no concern of overheating the alternator. What would happen is that the batteries would simply take longer to get a full charge. Batteries like the Odyssey charge at a high rate for a few minutes, and then taper off till fully charged.
