WTF door locks!
srtchick
2004 Silver SRT-4/06 STI
hey all... well it looks like my door locks have gone wacky everytime i push the unlock button form inside the car the locks go up the immediatly down so i have to manualy unlock the car even with the keyless entry in does unlock the driver door but all the other doors stay locked WTF ?! has anyone else had(have) this problem ???? i guess i gotta take it to mazda... tuh!:wtf: :confused:
PS i intalled my injen intake yest.. omfg its great !
Joe's gonna s***! CAI on his car! JK, I know the difference too...
As for the doorlocks, sounds like a stuck relay in the alarm module or the keyless module. They may have to be replaced, but sometimes tapping on the case or unplugging them will fix it.
Britt
maybe mine is busted, but for mine I hit unlock once for the driver door, and one more time to unlock everything else
Try the power lock diagnostic...
Remove the key from ignition.
Close all doors.
Open driver-side door.
Put key in ignition.
Turn key to ON, then back to LOCK, (4) times.
Push the driver-side door lock switch (3) times.
After that, these things should happen:
All doors lock.
Driver-side doors unlock.
Passenger-side doors unlock.
Hazard lights flash and horn sounds.
If that doesn't work, take it in for service; there's something going on with the power lock module.
you're fine. that's how they're supposed to work.
Close all doors.
All doors lock.
up up, down, down, left, right, left, right, b, a....ok now start your car! :D sorry, couldn't resist.
yeah, same thing happened to mine.......twice in 4 months now
teenage mutant ninja turtles 3 for NES.
up up down down left right left right a b select select start
i cant ******* believe i remember that.
interesting....does someone here knows how to reprogram the alarm....i just dont want it so noisy...
i hate that 3 horns when arming....
and sometimes at any time, the alarm gets crazy, imagine that @ 3am when im sleeping
there's a sensor under the sterring wheel....you can adjust it...it could be too sensitive. Mine kept on alarming with rain drops....and loud music or rumbling exhaust from a Harley or Muscle car. Just look for the box with the white nob and increase or reduce the sensitivity.
Contra Rules All!!!!!
It was up up, down, down, left, right, left, right, b, a, select, start your car.
I know what problem you have becuz I had it but the solution is: When you press 1 time on the unlock button, the driver's door unlock and when you press a second time on the unlock button, all the other doors unlock! It's not a problem, you simply didn't try it 2 times !!!
See ya
Similar Threads and Articles
