WTB:: Mazdaspeed Protege Transmission
I need a whole new transmission or housing basically..one night ripping on the car i cracked the housing right through. It shifted gears inside an made the bearings brake as well and snapped a fork/tooth off the pressure plate on a stage 2 SPEC clutch. Ill take used trans or broken trans anything i need help!! ill take ideas as well to were i can get one cheap.
brmiley
Mazdaspeed Protege..Laser Blue
theres nothing wrong with either of them? inspected for cracks cause i had a hair pin crack straight through..
brmiley
Sounds good i gotta figure out my money situation in pay pal and all that n talk to my trans guy make sure hes deff i need these and ill get back to you either late tonight or tomorrow around this time. is that okay?
Focus
MSP and RX-7
That's fine, in the meantime I'll get you some pics according to forum rules...
'02 ES
not trying to thread-jack, but what does a whole, good condition, MSP tranny go for these days? ...and does the lsd diff fit in the standard 2.0 transmission housing?
Prodigy
G15M-R guru
'02 protege LX, (3, yes 3) '99 protege ES', '90 Miata, '89 240sx
$400-800
Yes (You'll have to install a pink speedo gear to the msp lsd if you'd like your speedometer to function. The MSPs get their speed signal from the ABS sensors.)
