WTB: Cam Position Sensor Plug
Status
Not open for further replies.
25FConv
Mazda Protege
So the Ground wire to my CAm position sensor wire broke at the plug. I need a Cam position sensor plug, if anyone has a wire harness they don't need that plug on. I need it asap. please help.
Did you ever try taking the plug apart. I mean taking the pins out the back from the harness plug, remove damaged wire from pin. Splice the wire and insert into pin,crimp it and install pin back into plug. You would need a hook and pick set to do this. I have repaired many wire and plug harness this way.
could u tell me where the sensor is located?
Its the two wire sensor on the bottom right of the valve cover.
I actually ended up doing just that.....had my car dyno'd since and put down 289hp and 294ft/lbs at 15psi.
does anyone know the torque in which we have to tighten the camshaft shims... i dont have a torque wrench,well not yet, but can i just tighten them by hand?
thx in advance
Status
