have you ever driven any non-DSC equipped cars with summer only tires in similar conditions and taken a similar action to see how the car reacted?
I drove a 1994 civic hatchback for ten years with poorly treaded all seasons. I think I bought new tires for it once when I went in for new valve stems, and they said my steel belts were actually desintegrating, and I was probably going to die when they burst. I had to slide around in ruts a lot in that car, if I slowed down it would be stuck there until spring! Also, a 1987 2WD Wrangler with not so much what I'd call tires but rubber canvases, and rear drum brakes that - only - seized and locked up under any amount of braking. 2003 Corolla, 2005 Accord...um....bad work trucks that had no business being plated with tires the "company" deemed reasonable. This is my first DSC-equipped vehicle that I've driven under poor conditions.
They were all easily controllable in a slide situation and they all reacted as expected - the Wrangler defintely had to be caressed into turns and was prone to stalling randomly, but it too could be feathered back in line with a touch of steering angle when it got out. If it had DSC, it probably would have never moved, which is probably the best recommendation for that junker. The bad work trucks were the worst, I'll take the MS3 with Potenzas any day over those.
Also, to the Kindersley man, I'm from the City that Rhymes with Fun.
