solidtrance
- HIS: 2005 RX-8 WWP GT 6MT* HERS: 2006 Speed6 BCM 6MT**
THE PLAN
Winter is officially on us, so it is time for me to get busy with the rest of my plans. I would like to do a few mods to get my 8 in better shape to handle a few track days this spring and summer. I have already done a few things:
Engine - Cobb Acessport
Brakes – Axxis Ultimate pads F/R, SS lines, ATE fluid
Exhaust – Agency Power CBE with dual resonated midpipe
Intake – Airbox mod with K&N drop in, VFAD removed
I don't plan any more cosmetic changes for now, I just want to focus on improving the performance. That basically leaves me with the suspension and an extensive tune up. Here are my plans as they stand.
Suspension:
Progress Technology Springs Purchased 2/15/10 - Rec 2/17/10 - Inst 2/20/10 ***DONE***
Koni Yellows Purchased 2/15/10 - Rec 2/17/10 - Inst 2/20/10 ***DONE***
Lightweight 17X9 or 18X9 Rims with some aggressive rubber **edit: see below
Progress Technology FSB Purchased 2/15/10 - Rec 2/17/10 - Inst 2/20/10 ***DONE***
F/R Agency Power endlinks Purchased 2/10/10 - Rec 2/10/10 - Inst 2/20/10 ***DONE***
Exhaust:
Add Davesport 100cpi highflow
swap tips (no more 4.5in stupidity) Ordered 3/2/10 - rec 3/15/10 - inst 3/18/10 ***DONE***
GT Spec Header (Not sure yet??) ***DECIDED AGAINST THIS ONE***
Tune up:
Coils (OEM) Ordered 2/7/10 - rec 3/3/10 - inst 3/4/10 ***DONE***
Wires (ULTRA) Ordered 2/7/10 - rec 2/14/10 - inst 3/4/10 ***DONE***
Plugs (OEM, NKG) Ordered 2/7/10 - rec 2/14/10 - inst 3/4/10 ***DONE***
Walbro Fuel Pump (255lhp drop in)
Misc:
Axial Flow Engineering Master cylinder brace Just put back into production ???
Axial Flow Engineering STS Purchased 1/15/10 – rec 2/4/10 - inst 2/6/10 ***DONE***
Racing Beat Gaugepod w/ Prosport OIL pres, Oil temp, and Water temp Ordered 2/7/10 - rec 2/14/10 - inst 5/16/10
Race Roots Clutch Pedal Brace Ordered 1/29/10 - rec 2/4/10 - inst 2/6/10 ***DONE***
Racing Beat Ramair Duct
I will keep this updated as the winter goes along, and maybe add some pics as these projects progress.
****WINTER '11 UPDATE****
Well, Its winter again, so I will be piling up the parts for an early spring install. Not much left that I want to do at this point. I am thinking of doing the following;
Brake Rotors F/R
Front Pads (I already have another set of Axxis ULT's, and I think the rear pads are still good)
Finally getting a dedicated summer Wheel/Tire comb. Currently leaning toward some gold RPF1 17X9 with Star Specs/RE-11/RS3
RSB, I will most likely get the Progress Tech
Other than that I will be continuing the work on my wifes MS6. So far I have installed a PG SRI, Cobb TIP, ITV-22 step colder plugs, SLS Test Pipe and a borrowed (while a buddies car is in the shop) AP that I will buy from him and keep since I think he wants to get rid of it. For her car I am looking at the following;
ETS Top Mount
F/R Sways
Res delete (maybe?)
.....and in the distant future maybe a reworked K04 of 2871, who knows. Actually I am just waiting for her to blow it up so I can build the motor with a little help from the gang @ PG. If you have ever seen her drive you will know why this is in the cards.
Suspension:
Exhaust:
Tune up:
Misc:
Brake Rotors F/R
ETS Top Mount
F/R Sways
Res delete (maybe?)
