Update 1/8/07: Crazy night full of highs
and lows. I got a lot done.
First the lows:I bought injector pintles thinking it was just something I lost. according to mazdatrix these are often "lost"(in a socks kind of way) when removing the injectors and rails. I also recalled something sliding off in a distant memory. The pintles I bought seemed too small for the tips and asked mazdatrix what the deal was and they said that they need to be slid on after boiling them or pressed in with a vice.
me boiling it
Now a fuel injector to me seems like a pretty delicate item so any ham-fisting or mechanical force to drive it on kind of alarmed me. Nonetheless I proceeded and forced these onto the tips only to find that now they don't fit into the injector primary. Now breaking off a primary into one of the chambers is a much more serious problem than breaking an injector so I decided to carefully cut them off the injector tip. Luckily they split like a sausage casing and they came off without any trouble.
I consulted the fuel rail with the other two injectors on the UIM and saw that they didn't have anything. I concluded the pintle is only used when rebuilding the injector and you press the parts inside it. In effect what I did was slide a pintle over a pintle. A pintle is from what I can tell used for other purposes on other cars and may easily slide on/off. My confusion cost me a lot of time on this.
Another thing I wanted to do which was kind of causing me to put all this work off was rearrange some of the omp lines orders of installation. I ended up moving all of them around and completely removing all of them which completely rendered the new crush washers worthless. I said **** it and just tightened them more. I hope the heat cycling will work them in. I may not have mentioned this before but I primed all the lines with a hypodermic needle filled with oil otherwise the apex seal will not be lubricated while the lines are filling.
I had to put on and remove this stupid emissions rack about five times.
1st time: had to put on injector plugs
2nd time: forgot to put on a hose which was my number one goal(fist post) of this install
3rd time: forgot to put on an elbow that leads to the three way check valve on the rack
4th time: stripped a bolt!
5th time: finally in
This is the bolt hole. Not a horrible place to strip a bolt but I did hear a high pitched crack. I only pray that it is just a thread and not a hairline crack in the housing.
Senders installed with minimal clearance from the fuel line. There is also the vent line going to the charcoal cannister goal #1 finnished
Shot of the progress from the drivers side
Shot from the passenger side. As you can see everything fits prettymuch as tight as it can get and doesn't leave room for experimentation and alternate line routing
