WingsWest 3D mesh installed
505zoom
Breathe
2003 MSP #119
I installed the WW mesh in the lower grill today, I did not have quite enough from one sheet to do both grills. That's okay though because now I have some extra mesh to make some custom fog covers:).
After having the stock upper grill off the car, I don't think that there is an easy way to install this mesh there. I am now going with an aftermarket grill like the DG, and will install the 3D mesh in that.
There is a small blemish along the top, just right of center, that got a little bent and wasn't very apparent untill it was back on the car. I will be fixing that tomorrow, so I only took one pic today:
I threw those on from my other car for the winter months, they are Motegi Racing universal 17's. As you can see, they are the gunmetal, 7 spoke wheels.
post some zoomed in pics of the edges especially so i can see how u attached it. i had to kinda mickey mouse mine in there...
I was JUUUUST able to get enough mesh out of one sheet for the autoexe grill and for the lower grill but it was close, i called up WW to b**** to them about putting the 4 inches of solid aluminum along one side......
(lol) Yeah, I guess I did too. I just bent the mesh to the shape of the old grill, and then attatched it by bending the edges around the back of the opening. It still isn't perfect, so I will post some pics later this week when I finish. The lower right corner is still a little sketchy, and the bend along the top edge is not quite the same all the way across. Other than that though, it's almost perfect.
Also, I'm hopefully getting a better camera tomorrow, so I will probably take a lot of new pics this week. I just finished my blue interior lighting today, but my camera just doesn't take very good night shots so you can't see all of the lights. :(
Yeah, if the solid part had been punched, it would have been easy to do both. I traced out the stock grill onto the center of the sheet, and then cut about 1" extra all the way around so I could attatch it the way I did. If I hadn't used the extra, I could have made one for the autoexe style grill for sure. Actually, how wide of a strip did you use for the autoexe grill??? I haven't seen one in person, but I think I might actually still have enough. Thanks man.
