Will this work
Do we really need the oil pressure sensor, because I tapped into that spot, and I am tunning a T with the oil pressure switch. I think that side is leaking. If I don't need it I am going to take it off.
Let me know what you guys think
if your remove it it won't do any harm unless you have a drop in oil pressure then your idiot light won't come on. When I had the turbo I used a NOS Y fitting in that area to get a smooth flow and even pressure to both the sensor and the AN line going to the turbo. But I also had a Oil pressure gauge so the electric sender for that was hooked to it much heavier......all I did was make sure I used plenty of a liquid teflon sealant used on race cars and it did the trick no leaks.
I don't think that it is leaking anymore. I put some high heat teflon on there, alot of it. I think it stopped. Thanks for the reply chdesign.
