Will These Fit??
CANMP3
I have a MP3. I will have eibach pro kit springs on in a week, and have 215/40/17 tires. I want a set of 5zigen MK6 rims and they have a 43 offset. Will these fit the mp3 with no problems.
(I have already pm'ed Richie, but he must be busy)
Any help would be appreciated except for people telling me to do a search.
Chris
well its TRUELY going to depend on the size of the wheels you ordered....IF you ordered 7 inch wide wheels then you will be fine....if you ordered 7 1/2 inch wide wheels you MIGHT rub a little...you will just have to wait and see.
there is a fitment guide at the top of the fourm...and it has all this information in it....and its from RISHIE
lets put it this way......MOST tire makers will NOT recommend a tire that wide for a 6 inch wheel, which the stockers are, BUT there are a few members that have put them on and are running them. The only thing is....if you do run them on your stockers....and you have a tire problem...the tire maker most likely will NOT warranty the tires.....the place that sold them to you MIGHT...but not the tire maker.
Thanks for the imput guys, I will be ordering them as they are 7" wide, so I think I will be ok but barely.
seeing as how you have a sedan....and you are staying with the 7" wide wheel...you will be fine....NO PROBLEM...even lowered.
