S stockms3 Member Oct 2, 2008 #1 Since Im looking for a winter set, and I found one at a good price I need an answer quick!. That's why I didn't keep searching! Here r the specs: 16x6.5" with +45mm offset Bolt pattern: 5X114.3
K Kain Member Oct 2, 2008 #3 Impossible to tell just based on those specs. You need to know backspacing, spoke design, etc. Even then, at 16" you pretty much need to test fit it first to see if it'll spin free and clear the caliper (especially if it has balance weights).
S stockms3 Member Oct 2, 2008 #4 ooooooooooo thank you very much I will talk to teh guy see if I could test fit them.
