Will these fit?
stockms3
Since Im looking for a winter set, and I found one at a good price I need an answer quick!. That's why I didn't keep searching!
Here r the specs:
16x6.5" with +45mm offset
Bolt pattern: 5X114.3
Impossible to tell just based on those specs. You need to know backspacing, spoke design, etc. Even then, at 16" you pretty much need to test fit it first to see if it'll spin free and clear the caliper (especially if it has balance weights).
