Will not lock with key fob or interior button (2016.5 CX-5 Sport)
Nice job. I imagine you probably saved a pretty large chunk of money by getting that fixed on your own instead of at a dealer.
For sure. The labor alone would have been a couple hundred not to mention the parts and the time it would have taken to figure it out.
Not sure what the cause as I have done nothing that would affect the electrical system. Hopefully it was just a faulty part.
Looks like there’re 2 part numbers for RBCM and which one did you get?
Body Control Module - Mazda (KD45-67-5Y0G) OEM Mazda Body Control Module For 2013-2018 Mazda
Other Names:Controller, Module, Bcm Rear
Description:
CX-5. Mazda3. Modules & relays, rear body.
Controller - Mazda (G46C-67-5Y0B) OEM Mazda Controller For 2016 Mazda CX-5
Other Names:Body Control Module
Description:
Modules, rear.
A while ago a member from Russia did component repair on his burned-out RBCM. Really impressed!
I damaged my RBCM in the process of installation of additional LEDs. I didn't unplug the battery...(burn) and the mosfet Q15 was burned. There are two variants of such MOSFETs: SOT23-6 (replacement ZXMN6A08E6) and SC-62(replacement 2sk3065).
attachment.php
Hi folks,
I realize this might be a recurring topic, but I'm really struggling with a problem concerning the driver side door lock in my 2015 CX-5. I'm considering trying out a used rear BCM to see if it resolves the issue. Could anyone guide me on accessing the rear BCM in a Mazda CX-5?
Thanks a lot in advance.
