Will 18x8 offset +45 fit on 2008 GT?
What tires? I have 18's on my 5 with no problem.
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
If you had 225-40/18 tires on your 18X8/45mm offset wheels:
Package is 3 mm (0.1'') closer to suspension/brakes components. Acceptable for most cars.
Package will stick out 17 mm (0.7'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
