B brabbani Member : 2002 Mazda Protege5 Oct 13, 2003 #1 what's the widest tire i could fit on my 02 p5?
K KYMP5 Contributor : 04 Mazda RX-8 Oct 13, 2003 #2 search, there was a lenghty discussion about this a while back. if you cant find it im sure someone remembers. what size wheel?
S Sir Nuke Member Oct 13, 2003 #3 using the proper wheel, proper suspension set up....and NEVER have any rubbing.....a 215/40/17 is the tire for you.
L low_psi Member Contributor : ms|slowtege #399 Oct 13, 2003 #4 Sir Nuke said: using the proper wheel, proper suspension set up....and NEVER have any rubbing.....a 215/40/17 is the tire for you. Click to expand... AH SNAP! sir nuke is back
V viral_override Member : Red Pro 5 Oct 14, 2003 #6 I m on those those right now. I get a little rub with two in the back. But I think a stiffen suspension will fix it. It s just inside the well.
P Padanky Member : 03' P5 (gone), 05' xB (gone) Oct 16, 2003 #8 brabbani said: what about 215/45/17? Click to expand... I just bought rims and tires tonight and I got 215/45/17, I don't know yet if I like the look of the tire, think they might be a little to thick.
