Bigg Tim said:
These statements are absolutly not true when it comes to the MPI. I had ZERO issues with my maps from the time I did them at the dyno day, until I changed my wiring around to test out different things. I only changed a little timing because I'm a wimp and wanted to keep it safe at the end of the summer because the 94 octane gas isn't availble here anymore. I did no fuel changes and the car ran the same then as it does now. I have never lost any maps or settings, nor has my ECU learned the tune once it was done!
You can not say they are not true. There are people who have repeatedly had that problem. I'd bet you money if you drive 3,000 miles across the country, through a good portion of mountains etc... you WILL lean out portions of your map. There are multiple people who have tuned their car and had the tune fade out or disappear. I have personally first hand witnessed it occur repeatedly. So while it may not happen every time it DOES happen and your statement that it is "absolutely not true" is absolutely false.
My car ran completely like stock the whole time, just like it is now that I have it setup to run like stock. The TM keeps the ECU from learning anything that I do. So why spend the extra money on a fuel standalone, that you use in parralel, when you can get it done right for a fraction of the cost.
Not to say that Terry's 253whp is a joke, but he dynoed at 5 more psi then me, with a standalone, and only made 25 more whp. I understand the clutch was slipping, but that isn't that impressing now that there are more and more high powered cars out there. I would expect a standalone, with all the talk about them, to be a much better performing system and put down more power. I may have a larger turbo, but I'm not even in it's efficiency range yet, so that's no reason to use.
i've said repeatedly, and you seem to miss the point, that the MPI is a great unit and I do recommend that people buy it.
Also, Terry's dyno was well before anyone was doing jack with these cars. You also completely forget that the CLUTCH WAS SLIPPING, and they couldn't dyno it further. So you don't know what it can or can't do or what it would do. Also, if you look at his AFR's he appears to have went past peak efficiency. Also, I have his maps from when he did that and the timing seemed conservative to what I mapped with the JandS. So there was plenty of power to be had.
My point is that my car drives BETTER than stock when fully tuned. So if your car drives as good as stock... well then
. (Just giving you s*** with the well then, but the car did drive better than stock once tuned).
ALSO, I believe you have a bigger turbo for sure. This car runs a 16G which is not that large of a turbo, quite a bit smaller and less efficient than the T3 I believe, (and you have the T4 hybrid correct?), although I'd have to check maps to be sure.
I've been running the same psi since day 1 (16months) with no problems. I would say I've been in the same neighborhod of power the whole time, so the MPI is a very reliable unit to work with. I can't see how much easier it can get, you add or subtract numbers and have 3 tabs of maps to tune, if using the xtra injectors. I'm sure the other EMS are great, but this is by far the most bang for the buck!
I've never said the MPI wasn't the most bang for the buck. Eas up a little Tim. I'm a fan of the MPI, and always will be. It does the most for the cost of anything out there. But it is NOT perfect (nore is an EMS). So don't try to pass it off as the cure all to end all to elminate all EMS's. It's an AWESOME unit, but it HAS lost maps, that's the ONLY complaint or statement I'm putting forward amidst a heavy set of praise.
You can tune the Microtech with one hand while driving... also, you don't need a laptop and can program it with the hand adapter that can be purchased instead of the laptop kit. There are OTHER options basically with the situation. There ARE things you can do with a standalone that the MPI is likely to be more limited on.
But Nick also made a GREAT point in this thread or another... why use a standalone to control boost, when they make boost controllers that do a better job.
This isn't a war for EMS's and I will NOT get involved in some inane pissing match like perfworks use to love. If you can't understand and appreciate that I think the MPI is a great unit and that I have seen a particular problem show up a few times and accept that at face value rather than seen as an attack then there is no point in trying to continue an educated discussion of EMS units. They ALL have flaws, and if you try to maintain that the MPI will not come upon shortcomings from time to time then this is not an honest exchange.
GO MPI, GO MICROTECH, GO AEM, GO HALTECH.
