I'm sure with all that money, you can just, give it to me..
twilightprotege said:all i can say is I WANT THAT INTAKE MANIFOLD!!!!! when are we ever going to get a replacement for our stock one?????? YOU AFTERMARKET PPL LISTEN TO ME!!!!! hehehehe
300whp would be rather easy with a T04E turbo. considering what the nissan ppl get out of the SR20DET, with enough money the FS could handle 600whp
Matthew said:im just dying to save up the money. i had money saved up but im getting screwed. i might have to go to the bbb. tell me how this ******* makes sense:
i refinance my car, the credit union calls mazda credit for payoff and makes check out in that amount.
i call mazda and tell them to stop my elec deduction but they try to say they cant stop it, so my account is debited 361 as usual on the first. so im like whatever ill get a check for 360 for overpaying. guess how much the check was????
19 MOTHERFUCKING DOLLARS!!! what kind of math are those ******* idiots using???????????
/rant
so it will be a blow-thru?paulmp3 said:i am trying to get wagnermotorsports to make us one. We will have one soon. A piggyback or fuel control will be needed b/c the butterfly will be removed so fuel curves will need to be adjusted.
boostisgood said:I am jsut wondering why everyone says the fs is only good to make 250 WHP ? Has anyone gone beyond that and blown up? If so, was the car properly tuned, with full stand alone, upgraded injectors, properly Monitored ? Was the timing map programmed with the increase of boost ? Were the fuel maps also programmed accordingly ?
It just dumbfounds me that everyone says this, but no concrete info, that I have found, to prove this. I believe this engine could handle 275-300 WHP, and easily 16-20 LBS of boost, with proper tuning.
I say this for the simple fact that Howell automotive, a well known Neon tuning company, has a frikin 1st gen SOHC, pumping 320+ WHP on 20 lbs of boost. That damn engine is build weaker then the FS, and handles this daily.
It is ALL about how the car is built. Lets see what I get.![]()
AFaceInTheCrowd said:so it will be a blow-thru?
twilightprotege said:oh, by the way, VICS is a system mazda has to reduce the length of the intake manifold runners at high rpm to generate more power. VCTS is a system where is "tumbles" the air right near the head so at cold operating temps (start up) it's environmentally friendly (aussie P5's done have VCTS).
Installshield 2 said:the website said 561whp and a test weight of 2100lbs![]()
paulmp3 said:Do you mind sharing that link with me, i searched and gound nothing.
