[syko.xero]
is flashed and has been running over stock boost levels? How has the car seemed in doing so?
oldschool said:I'm flashed and running 10-11psi now with no problems. as soon as i let her breath better (ie SRI & exhaust) i'm goin' higher!
When you put on the SRI you will actually have a lower margin before it cuts fuel. If you plan on the SRI and want more than 10-11 you will need an FCD.
