I run Kuhmo Ecsta V700s. Best tire for our stock suspension setup. Hoosiers require at leat -2deg camber, and stock you won't get there.
The V700s will wear weird over time, but you can rotate them on the rim and run them backwards after they wear in good. No loss in performance, and you'll get to wear the other side out then.
