Which SPRINGS?
splitvizion
2004 Mazda 3S
I am looking at: Sprint - Eibach - Skunk2
Which springs are the best value but still give a quality ride for a car that is used as an everyday driver?
Thanks
Anthony
I have an Eibach Pro Kit in my daily driver and zero complaints.
Eibach seems to be the general publics preference. Does anyone out their have any reveiws on the other brands. Any money that I can save by going with another brand is always good but I dont want to sacrifice any quality. Thanks
Anthony
There are a few people with different brands on here. Look through this forum and you should find them pretty easily.
TEIN H-techs. the ride is so much better, and it lowers it to a perfect stance. i know they arent one of the original 3 you were looking into, but they might be worth checking out
It's camber.
And any springs that drop over 1" will need a camber kit unless you want to wear out the inside of your rear tires.
If the Tein is only .9", then you might be able to get away with it.
and if you drop over an inch and wish to do some camber correction, you will need a rim with AT LEAST 48 offset or you wont be able to correct it
I have the Tein H-Techs as well. Nice improvement over stock. Love the look and the handling improvement. I did get my car aligned afterwards. Camber was still in spec, but toe needed adjustment.
