Which Exhaust?
elderlycoffee
2007 Sunlight Silver mazdaspeed 3
Ok, I want to upgrade my exhaust.
I'm leaning towards the Mazdaspeed exhaust just because I don't want to void any warranty yet but which is the best on the market right now?
I highly doubt exhaust will do anything to your warranty no matter what kind you get. Obviously they'd deny any claims relating to the exhaust but it shouldn't do anything to the rest of your warranty.
You have to decide what exhaust mods youre going to do in the future.
If you plan on going test pipe down the road or even downpipe, consider the mazaspped, ghl or cpe... Than you can add the corkspork dp and a test pipe down the road without having to change your new exhaust.
If you get the vibrant, you get a high flow cat with the setup. Im not sure if the CS DP fits this though.
I have the vibrant with a corksport down pipe. They work well together. Vibrant has an advantage with making power because it removes the 2nd factory cat. If you only want a cat back get this one. Only problem is you can not use a cp-e down pipe but corksport and turbo xs have compatible pipes anyway.
