the gamper
So I go to my Local Oil change shop to get my oil changed and tires rotated. Been going there for years, lots of oil changes and tire rotations.
I didnt see it happen, but my car was up on a hoist getting the tires rotated, it was taking a very long time, I go to see what is up and the wheel lock shattered when they tried to remove it with the key I supplied them. Half the wheel lock is stuck in the key and half on the stud, fused to the hub making it impossible to get the rim off.
The dealership said that it probably wont be covered under any type of warranty claim, even though the locks are a Mazda accessory. The service tech said that they probably used the pneumatic impact wrench (compressed air wrench) which is what caused it to shatter, thus the warranty would not cover. I was never aware of any such limitation.
As luck would have it, the guys at the oil change shop decided to take the matter into their own hands and used a chisel and hammer to try to and remove the remnants of the wheel lock still on the hub. Would have been nice if they asked me first. I am not sure of a better way to go about it, but this damaged my rim somewhat (no big loss) but more importantly damaged the threads on the stud.
Not sure on how this is going to play out, but I have never seen anyone use anything other than the impact wrench to loosen the wheel locks, never had any issues before. In fact the owners manual is silent on using an impact wrench vs. torque wrench.
So what do you think, should this should be a warranty repair? Or am I SOL? I have a feeling this is going to be one expensive tire rotation.
