Wheel Hop and Radius arm kits?
speedfrk
Has anyone Heard of this ? And what would be the draw backs to a kit for our cars like this?
Radius Arm Traction Bars
One problem I've been having a lot lately is wheelhop when launching. It's not like I'm at a drag strip, either; just pulling out onto a busy street can yield horrible wheel hop if I'm not careful with the clutch and gas. I believe the rubber motor mounts have become worn out with age; visual inspection during my timing belt change showed the front left lower mount to be severely cracked. Two methods Radius arms systems consist of a crossmember and two rods which attach to the front suspension's lower control arms. They reduce or prevent wheel hop by preloading the front suspension, preventing the caster from changing when launching. There are currently four such systems available for the Integra; all of them attach to the factory towhook locations in front, but differ in where along this crossmember the radius arms are mounted. The four systems are from Competition Engineering, Z10 Engineering, JimFab.com, and Lakewood Industries.
The Z10 bars, while seriously overpriced at $675 for the chrome-moly version, are popular and advertise that they can be used on the street, with no suspension binding. However I seriously doubt this claim. After reading some posts on Honda-Tech by the original designer of Z10's radius arm system, with a detailed description of why both the CE and Z10 bars have flawed designs, I have to agree assuming the given information is correct.
Basically, the theory is that the front suspension's lower control arm rotates around a fixed axis (which can be seen by the two locations it mounts to the body at). A radius arm attached to this control arm, in order to avoid binding, must also mount to the chassis along this axis. Some trigonometric analysis shows why this is true: I don't have any diagrams to show, but I'll leave it as an exercise to you to use your high school math skills to confirm my results if you wish. In summary, if the radius arm mounts to a point on the chassis closer to the outside of the car (as in the Competition Engineering system), the radius arm will be placed under tension as the suspension compresses. If it mounts to a point closer to the centerline of the car (as in the Z10 system), the radius arm will be placed in compression as the suspension compresses. Either way is undesirable since the suspension's travel will be limited, though the Z10 will have less of an effect since its arms are longer and thus will allow more travel before the binding becomes noticeable.
This all seems pretty pathetic if you ask me, since it only took me about 10 minutes to do all the calculations for myself, and I'm not even a mechanical engineer (and haven't done much real math since graduating college 5 years ago!); in fact, I was able to figure this out with high school level math. The alternative to this bad engineering is possibly the system from JimFab.com; according to what I read on Honda-Tech, this system places the radius arm mounts along this critical axis where they should be. In addition, their system is made from chrome-moly steel, and costs substantially less than Z10's.
One last possibility is the system from Lakewood Industries. Their website isn't all that easy to navigate, but they have both powder-coated steel and titanium traction bars (weighing 16 lbs. and 10 lbs., respectively). Unfortunately, they have no prices listed, and I haven't read anything about whether their geometry is correct or not. Just by looking at the photo, it appears that they're somewhere between the
to reduce wheel hop are stiffer motor mounts and radius arm traction systems." Here is a link with pics of what it is http://integramod.tripod.com/ideas/ideas1.html
I looked at our cars and Know that this could be designed to bolt up at the tow hooks on the front of the MSP but havent figured out the control arms yet and am not sure if it will be a benefit ? Would anyone know the calculations for desingning the geometry for this setup?
Dissapointment?!
I feel so dissapointed that an article on something as gay as the Tweel has recieved more replies than this one . !?!?!?!
We don't drive a neon. The way the engine mounts are on the protege a simple stiffer motor mount will fix the wheel hop issue. Also alot cheaper.
Not to mention that even with stiffer mounts , They are a very poorly designed location for mounts . I know for a fact that it will not fully address the issues of wheel hop. So what would be the draw backs to designing a Radius arm kit that would give people another option. In my opnion motor mounts are not the end of the wheel hop problem.
I'm not really sure wht you mean by that. I actually had a lakewood slapper bar ghetto attached to my oil pan to stop the wheel hop before I put the mounts in.
The location of the mounts are actually in a decent spot. Take a look at a srt-4 if you want to see a poorly designed set-up. The stiffer mounts eliminate 98% of wheelhop. Take away the stiff sidewall tires and all the wheelhp is eliminated.
There is a huge disadvantage to the radius arm kit. One would be you can't drive on the street with it on, as it's not designed for bumps or uneven surfaces. So that means you would have to jack the car up to take links off. On top of that they are wicked expensive.
KEep in mind these aftermarket urathen Motormounts are made by AWR motorsports and they know there s***. They are race proven on the Speed world challenge tour. And they are so bad ass they are sold on Mazda Motorsports which in order to order parts you have to race your car in 3 sanctioned events.
Needless to say if you replace the mounts they will give you good race performance that has been tested over and over again. AWR stand by their products and they make top notch stuff. They may not be the end but they fix alot of it. Wheel hop doesnt stop at just your mounts (i.e. tires are another factor) but alot of it is...im willing to go out and say if you replace the front and rear with M/T mounts (harsh idle) you will fix 90% or more of your wheel hop....which is alot.
I have a picture of the stock fornt mount vs AWR M/T front mount...HUGE difference. Stock mounts have alot....LOTS of play in it....its for comfort and not performance. Stiffer mounts reduce driveline lash.
AWR sells race spec Control arms for proteges but its highly recomended for racing purpose only...my guess is due to a harsh ride on daily driven streets. They do look hot!
I think you all missed the point and am sad that this is the best conversation that I can get on a good subject. Not to mention that properly designed radius arm kit is fully street functional , (Alot of cars are equiped with a factory setup.) I also never said that I hated motor mounts Just trying to be open minded and give the MSP community all the options and what not . I feel that a NO NO negative attitude is why new products and options are not ever available for mazda owners. And oh s*** those mounts must be gold plated to get so much priase from you ! LOL they are the standard upgraded mounts and do there job well . But does that mean never check anything else out ? Oh well I tried?
If motor mounts fix wheel hop problem on a protege, (which they do when equipped with softer sidewall tires), why would you spend 500-700$ on a traction bar set-up? I totally agree with you on getting new products for the Protege, however if it's not needed, it's not needed. I have over 320+ quarter mile passes on my MSP running anything from the stock tires (13.81), 205/50/15 drag radials (13.40), 235/50/15 drag radials (13.34), 26/9/15 slicks (13.15). All with zero wheel hop. All for what 120?
Get the stiffer mounts and a softer sidewall tire, then go to the track and have fun. Save the money and energy for something that would be really functional for the Protege.
I dont see softer sidewall tires being all that cheap of an investment either . Not to mention the engine movement is not the only equation in wheel hop . Alot of it is in suspension . Spring rates and dampners play into the problem also. And not all of us are worried about the investment cost for the product . Some of us care about the function. Also for people who are too much of a cry baby to deal with the extra vibration from engine mounts this may be a good way to go . You could use them with the stiffer front mount or ??? You never know.
okay if you want to get rid of wheel hop go to www.awrracing.com
They sell race spec parts that eliminates wheelp hop for a fiarly good price. The problem is its going to be a pain in the ass to get around town...since they are recomended for road racing or drag racing.
I dont think a radius control arm has any significant impact on our cars. If they did I think companies like tripoint or AWR would sell them.
here is one product they offer:
FRONT SUBFRAME REINFORCEMENT​
Modified (reinforced) stock front subframe - the brace running under the motor that picks up the front lower motor mount and bolts to the radiator support. A good addition for those who are experiencing motor movement and excess wheel hop in autocrossing or drag racing. Not recommended for street purpose. This is a modified stock unit, powder coated black
There are other supention goodies they make to help wheel hop but I still think the mounts are the best. You can eliminate all wheel hop but I assume the idle would be rought since the goal of eliminating wheel hop is to lessen motor movement...which equal vibration at idle.
Not really because you seem to be the one bitching and whining over a whole forum not replying to your post and when someone does you jsut tell them off and say "its like talking to a 15 year old"
whine and cry me a river.
speedfrk said:
Do you even read the posts I write . Never mind talking to you is like talking to 15 yr old .
Go for it...and test it out. I was just questioning is it nessecary, givent he alternatives. No one is stoping you, infact I think it maybe worth the try. go out find the right people and come back and report on your findings....dont get whinny and b**** over peopel dicussing this or not getting your point. YOu win the award for the member with the shortest fuse. yes, we are all kidos and 15 year old who dont know what you are talkign about.
Get ahold of TurfBurn or Deseling Motorsports..peopel who know alot about suspention moding and active forum members.
And please get the sand out of your coouch and stop hating the world...did I attack you or insulted you? So why you felt the need to insult me back is beyond me...I tried to be mature and you are the one acting like a 15 year old.
So whos the ******* 15 year old here? please....spare me the idiotic statment when you were the one who use immature words in your own post.
speedfrk said:
Do you even read the posts I write . Never mind talking to you is like talking to 15 yr old .[/QUOTE]
You help make my point even more . I didnt ask you to keep telling me about motor mounts I Have already stated I understand they do a good job. I was trying to find out if anyone on the forum ( BESIDES YOU WHO SEEMS REALLY F*&K HAPPY with your motor mounts ) Which I already stated is very cool I understand they do a good job. ) . So as I was saying. Maybe someone has had experience with them on a Mazda or other car and would like to have an ADULT CONVERSATION about it and what experience they have had with them. DUH ass HOLE! I never asked you to keep telling me how much you think other products would answer what I was discussing when that wasnt the point of the post . You must be 16 Im so SORRY! or you wouldnt feel so hurt! LOL ! SO SPACE MONKEY GO FIND SPACE GHOST AND BUZZ OFF!
You Know what let me end this right Here I am Sorry for starting a fight and hurting your feelings . Please except my appologies im sometimes a DICK. Thanks for your input I will keep it in mind . Thanks .
