03MSPRO said:I have a HKS TT set to TM 1.00 (manual timer of 1 minute). Half the times, it does not work. When It remove the key from the ignition, the car stalls and dies, why? What's going on? I hate headaches!!!
Lucky you!! Mine will work fine tomorrow.Dexter said:mine works fine.
03MSPRO said:My TT is fixed now. The wiring was wrong because someone on this board had the wires mixed up on his instructions
tytanium said:Care to elaborate so I can fix mine too? Thanks
marashka said:In the instructions that someone had here you were supposed to connect blue wire to blue and green to black and something, but actually it is the other way around......blue wire on the TT goes to black and something on the ignition and green wire on the TT goes to the blue on the ignition, if that made any sence. I was ******* with mine for a few hours b4 Dr.Sound (Vic) came over and we figured it out together. I have hks type-1.
